In reply to Subhra Bera:
thanks for your reply
i was trying what you said ,but i see you made function calls in initial block , is this example intended to be ran using vsim ? if yes then this is not what i meant
i will make my question more clear
here is the .sv file
module data_ex2 ();
export "DPI-C" function Double;
function void Double();
$display("hello from sv");
and now i want to make .c file , and run this task there , i generated the dpiheader.h file
and here is .c file
#include <stdio.h>
#include "dpiheader.h"
extern void Double();
int main (){
Double();
return 0 ;
and now i will compile it , i want to run the .c file and i am expecting it will print “hello from sv”
gcc main.c
and the output of this that linker says , no refrence for Double()
so that is exactly what i want , is this valid or DPI can not do that ?
thank you
