Can anyone suggest how to write assertion for this question. once enable is high in the next clock cycle one pulse on signal a( width is 1 clk cycle) should be generated every 10 clock cycles
property prop;
    @(posedge clk)
    if(enable)
      ##1 ((a) ##1 !a[*9])[*1:$];
endproperty : prop
I tried like this. As per the question if should run infinite time but I don’t get it.
This works
 module m;
  bit clk, enb, a;
  bit[2:0] p0, f0, p1, f1; //  p2, f2;
  initial forever #3 clk = !clk;
  // if enb && a then a==0 9 more times
  ap_a9: assert property(@ (posedge clk) enb && a  |-> ##1 !a[*9]);
  // never a==0 occuring 10 times in a row
  ap_no10a:  assert property(@ (posedge clk) enb  |->  not(!a[*10]));
    @(posedge clk) enb <= 1;
      repeat(3) begin
        @(posedge clk) a<=1;
         repeat(9)  @(posedge clk) a<=0;
https://systemverilog.us/vf/Cohen_Links_to_papers_books.pdf
module m;
  bit clk, enb, a;
 // Need to handle border cases on "a" after the fist rise of enb.
  // if new enb then ##1 a then no a 9 more times
 ap_a9enb: assert property(@ (posedge clk)  $rose(enb) |-> ##1 a ##1 !a[*9]);
 // if stable enb && a then a==0 9 more times
  ap_a9: assert property(@ (posedge clk) $stable( enb) && a |-> ##1 !a[*9]);
 // never a==0 occurring 10 times in a row
      repeat(3) begin
If (enable) is stable, you also require by the assertion that ( ##1 ((a)) matches. But the previous attempt requires !a repeated 9 times.
Yoiu have a new attempt at every clock. The other attempts will cause errors
module m;
  bit clk, enb, a;
  event e;
  ap_prop: assert property( @(posedge clk)
    if(enb) ##1 ((a) ##1 !a[*9])[*1:$]);
    int rp;
    repeat(15)  @(posedge clk) a<=1;
      repeat(10) begin
        if (!randomize(rp) with { rp >4; rp <15; }) ;
        //`uvm_error("MYERR", "This is a randomize error");
         repeat(rp)  @(posedge clk) a<=0;
      -> e;
Thank you so much Ben for this solution. Can you explain the significance of 4th assertion?
I was replying to the question and show that this is an incorrect answer because one attempt requires a==1 and then a==0.
but the next attempt requires a==1. That was a bad assertion
Okay Ben, thanks alot for solving query.
Updated with
/ if stable enb && a then a==0 9 more times. One "a" every 10
  ap_a9: assert property(@ (posedge clk) $stable( enb)  |->  a[=1] intersect 1[*10]);
// also remove the
// ap_no10a: assert property(@ (posedge clk)   enb |-> not(!a[*10]));
module m;
  bit clk, enb, a;
  ap_a9newa: assert property(@ (posedge clk) $stable( enb) && $rose(a) |-> ##1 !a[*9]);
 // if stable enb && a then a==0 9 more times. One "a" every 10
 // $stable( enb) && a |-> ##1 !a[*9]);
  // not needed
      repeat(3) begin
Thanks alot @ben2
