class reg_block extends uvm_reg_block;
rand custom_reg1 reg1[1:24];
rand custom_reg2 reg2;
constraint c1
(func(reg1)) -> (reg2.field1.value == 0);
function bit func(custom_reg1 regs[1:24]);
int count = 0;
foreach(regs[i])
if (regs[i].field2.value != 2'b10)
return 1;
return 0;
I just want to make sure that if at least one of the 24 reg1 field2 is not 2’b10, reg2.field1 should be 0.
Error-[IVCB-INTARG] Non integral function argument
…/uvm_env/***.sv, 489
***, “this.reg1”
The argument ‘this.reg1’ is not an integral expression or array.
Change the type of the expression or remove it from the constraint.
How can I achieve this?
