Could someone demarcate the boundaries of $past(d) and current value of d so that assertion passes visually.
Additionally, where would $sampled(d) be in the figure?
you can use
(##1; q === $past(d))
in a property. This helps avoid the false trigger at first edge
@ssureshgverifier Thanks. The problem is still around the boundaries of $past(). If $past() refers to the shaded orange region in the waveform, the assertion should fail but the assertion passes!
$past does not represent entire orange region. it gives value sampled in the ‘preponed event region’ during last clk edge. $sampled gives the value sampled at current timestep, again in the preponed region.
above waveform you gave does not show delta cycles to mark SV event region.
