Bitwise toggle coverage for a bitvector
I am trying to construct an array of covergroups in order to sample slices of a parameterized vector as follows:
module checker {
  clk,
  reset,
  sig
parameter WIDTH = 32;
input clk;
input reset;
input [WIDTH-1:0] sig;
// Declare generic covergroup
covergroup CG (ref reg _cp) @ (posedge clk);
  option.per_instance = 1;
  CP: coverpoint _cp;
endgroup
//Instantiate covergroup
CG cg[32];
for (int i=0; i < WIDTH; i=i+1) begin
  cg[i] = new(sig[i]);
This line:
CG cg[32]
Is causing the following compiler error: Syntactically this identifier appears to begin a datatype but it does not refer to a visible datatype in the current scope.
I guess I need to declare the covergroup outside the module, but I’m not sure what that would look like. Can anyone provide an example of what that looks like in my case?
