Bit Bash Sequence for Read Only Registers
In reply to yuvraj khare:
One more question regarding mirror task define in uvm ral , Is mirror task is valid for RO registers?
I am facing the issue, as am seeing the read data is coming correctly at BUS and same read data is coming at uvm_reg.svh also. But when am initiating the mirror task and read the same register, am getting an mis-match with DUT and mirrored value.
