Assignment of handles from paper " Yin and Yang of Obj Oriented Verification "
Thanks Dave , a final question
class  Base #( SIZE1 = 10  ) ;
//  Base#(()::SIZE1  below  is  at  default  10  (  4- state  signed  type )
 class  Subtype  #( SIZE2 = 1  )  extends  Base ;
 Base #(10)  b1 ;  //  4 - state  signed  parameter
Using the 4 assignments ( via different specialization of Subtype ) in Original Code ,
I observe all assignments are successful , even though the type parameter
( of handle b1 and Object handles s1 to s4 ) are Not Matching Types !!
    parameter  int  INTS  =  10 ;
    Subtype #( INTS )  s1  ;  //   2 - state  Signed  parameter  of  Size  32 .
   initial  begin
    s1  =  new()  ;
    b1  =  s1  ;
   parameter  int  unsigned INTU  =  10 ;
   Subtype #( INTU )  s2  ;  //   2 - state  Unsigned  parameter  with  range [31:0]
   initial  begin
    s2  =  new()  ;
    b1  =  s2  ;
 parameter  bit  signed  [131:100]  BIT =  10 ;   // Range  is  different  than  31:0  !!
 Subtype #( BIT )  s3  ;  //   2 - bit  Signed  parameter  of  Size  32
   initial  begin
    s3  =  new()  ;
    b1  =  s3  ;
   parameter  bit  signed  [15:0]  BIT =  10 ;
   Subtype #( BIT )  s4  ;  //   2 - bit  Signed  parameter  of  Size  16
   initial  begin
    s4  =  new()  ;
    b1  =  s4  ;
[Q] What makes all the 4 assignments legal in this case ??
