Assertion to check signal asserted for only one clock cycle
Hi Ben, Thank you for sharing your understanding.
property sva_p2;
  @(posedge clk) $rose(signal) |-> @(negedge clk) $fell(signal);
I tried this assertion “sva_p2” and it is working perfectly fine even with the cases mentioned above…
As our expectation, both cases are failing…
But now the question is that, Is the assertion “sva_p2” can be considered correct, As it is having posedge and negedge event of the same clock…
Waiting for your insight on the same,
Thank You,
Dhruvesh.B
