Assertion not triggering for Asynchronous FIFO
Hi all. I am trying to verify an asynchronous FIFO. Here is my code (it isn’t complete)
module afifo_sva #(
    parameter DATA_WIDTH = 64,
    parameter FIFO_DEPTH = 16
    // All signals of the DUT, as INPUTS only
    input logic i_rclk,
    input logic i_wclk,
    input logic i_rrst,
    input logic i_wrst,
    input logic i_wr_en,
    input logic i_rd_en,
    input [DATA_WIDTH-1:0] i_wdata,
    input logic [DATA_WIDTH-1:0] o_rdata,
    input logic o_wfull,
    input logic o_rempty
    localparam PTR_WIDTH = $clog2(FIFO_DEPTH);
    // Properties for Empty flag
    // Reset
    property p_empty_on_rrst;
        @(posedge i_rclk)
        i_rrst |-> ##[0:1] o_rempty;
    // Read last
    property p_read_makes_fifo_empty;
        @(posedge i_rclk)
        disable iff (i_rrst)
        (i_rd_en && !o_rempty &&
        (testbench_top.dut.rgraynext == testbench_top.dut.rq2_wgray))
        |=> o_rempty;
    // Write into empty FIFO
    // Sequence to detect i_wr_en at write clock.
    sequence s_wr_while_empty;
        @(posedge i_wclk)
        i_wr_en && o_rempty;
    endsequence
    sequence s_fifo_not_empty;
        @(posedge i_rclk)
        !o_rempty;
    endsequence
    property p_wr_en_when_empty;
        disable iff (i_wrst || i_rrst)
        s_wr_while_empty ##1 s_fifo_not_empty;
    // Properties for Full flag
    // Reset
    property p_full_on_wrst;
        @(posedge i_wclk)
        i_wrst |-> ##[0:1] !o_wfull;
    // Pointers
    property p_write_makes_fifo_full;
        @(posedge i_wclk)
        disable iff (i_wrst)
        (i_wr_en && !o_wfull &&
        (testbench_top.dut.wgraynext == {~testbench_top.dut.wq2_rgray[PTR_WIDTH:PTR_WIDTH-1],
                                        testbench_top.dut.wq2_rgray[PTR_WIDTH-2:0]}))
        |=> o_wfull;
    // Assertions
    a_empty_on_rrst: assert property (p_empty_on_rrst)
        else $fatal(1, "Empty flag did not assert on reset");
    a_full_on_wrst: assert property (p_full_on_wrst)
        else $fatal(1, "Full flag did not assert on reset");
    a_write_makes_fifo_full: assert property (p_write_makes_fifo_full)
        else $error("FIFO did not assert full after final valid write");
    a_read_makes_fifo_empty: assert property (p_read_makes_fifo_empty)
        else $error("FIFO did not assert empty after reading last item");
    a_wr_en_when_empty: assert property (p_wr_en_when_empty)
        $display("T=%0t PASS: FIFO became non-empty after writing into empty FIFO", $time);
        $fatal(1, "T=%0t FAIL: FIFO stayed empty after writing into empty FIFO", $time);
The assertion “a_wr_en_when_empty” (Write to empty fifo test) isn’t ever triggered. I have also tried the opposite conditions (o_rempty instead of !op_rempty), to no avail. Could someone point out where I might be going wrong? This is my first time using assertions.
Check if your disable expression (i_wrst || i_rrst) is true.
