write an assertion for 55mhz clock
this is my approach and this code is working fine for time, not working properly for realtime. Can some one find the issue?
`define PERIOD 10ns
module tb;
realtime TON = `PERIOD * 9.09;
realtime TOFF = `PERIOD * 9.09;
bit clock;
clock = 1;
always begin
#9.09 clock = 0;
#9.09 clock = 1;
property check_ton(int ton_time);
time current_time;
(1, current_time = $realtime) |=> @(negedge clock) (ton_time == ($realtime-current_time));
endproperty : check_ton
property check_toff(int toff_time);
time current_time;
(1, current_time = $realtime) |=> @(posedge clock) (toff_time == ($realtime-current_time));
endproperty : check_toff
assert property ( @(posedge clock) check_ton(TON))
$display($time," CHECK_TON : PASS");
else $warning($time," CHECK_TON : FAIL");
assert property ( @(negedge clock) check_toff(TOFF))
$display($time," CHECK_TOFF : PASS\n");
else $warning($time," CHECK_TOFF : FAIL\n");
$dumpfile("dump.vcd");
$dumpvars;
#50 $finish;
