Assertion binding
I don’t want to write assertion in my RTL design…i can ask verification engineer to write assertion binding the TB-RTL interface…right?
ABSOLUTELY!!! In fact, it is recommended that assertions be in a module or in checkers and be bound to the DUT. This is a preferred approach for the following reasons:
  1. It physically separates the verification environment from the DUT. Thus, adding or making changes to the assertion module bound to the DUT is a transparent thing.
  2. When synthesizing the RTL, some compiler time-stamp the compilation. Any change to the RTL, even to just tune or add assertions, would change the time-stamp, and thus redo the synthesis.
  3. Adding or changing assertions within the RTL model may accidentally cause changes to the RTL (like adding a character, changing names, or even deleting code, thus causing unnecessary headaches and aggravation.
  4. Often, it is necessary when writing assertions to add supporting code that is not intended for synthesis. There is a danger that this supporting code will be accepted by the synthesis tool as real RTL code, and that may impact on the performance or the design.
Question though: Why are you limiting the writing of the assertions to just the verification engineer? The verification engineer should write assertions in a separate module (or checker) to address the design requirements from the specificationa point of view. The RTL designer should write the assertions in a separate module from the design point of view. That would address things like the internal FSMs and their inter-relationships and relationships to outputs, assumptions about inputs or states or max sizes (e.g., FIFO depths, address range, etc.
Ben Cohen http://www.systemverilog.us/
  • SystemVerilog Assertions Handbook, 3rd Edition, 2013
  • A Pragmatic Approach to VMM Adoption
  • Using PSL/SUGAR … 2nd Edition
  • Real Chip Design and Verification
  • Cmpt Design by Example
  • VHDL books
