Assertion based query
In reply to atanubiswas:
Hi Rahul,
I checked it and you are correct. Is there any solution for that? I tried using automatic keyword for the function save_data… still the problem persists.
Only variables declared inside the automatic function are automatic. your function still might be using some other variables which declared outside the function which are still common for both the property call.
