In reply to Shubhabrata:
With some minor adjustments, you can vary the array size when calling randomize:
class test;
rand bit [2:0] arr[];
constraint arr_size_c {
soft arr.size == 6;
constraint arr_values_c {
foreach(arr[i])
arr[i] inside{[0:arr.size()-1]};
constraint arr_unique_c {
unique{arr};
$display("%0p",arr);
endclass : test
module top;
test t1;
t1 = new;
for (int i=5; i<=8; i++) begin
if (!t1.randomize() with {t1.arr.size == i;})
$display("Randomize failed");
endmodule : top
