I have a RISC-V based system that has separate instruction and data memory. The firmware calls an objcopy on the .elf to generate a .vh which is ready to be parsed by $readmemh.
If I have a single memory I could have simply used the following:
// NOTE: the buffer size is twice as big as the memory
// as we need to hold both instruction and data
bit [DW-1:0] buf [2*MEM_SIZE-1:0];
$readmemh("myfile", buf);
for (int i=0; i<2*MEM_SIZE; i++) begin
mem.write(buf[i]); // where mem is a uvm_mem object
I have two issues though:
- the file might only have few bytes that are necessary, the .text and .data sections plus some other ones are not going to cover the full memory. So loading irrespective of what is useful is a waste of resources (especially if doing front door access)
- As I have two such memories, I would need somehow to divvy up the buffer and only go through half of it for the instruction memory and the other half for the data memory.
Both problems are very annoying. Ideally I only want to load what’s necessary and leave the rest of the memory unitialized or randomly initialized. And secondly I’d like to write in the two memories separately, also because it is not uncommon to have different access type for data and instruction, which makes things complicated when you have your ECC working on different widths.
I thought about parsing the file myself but wondered if there was no better idea than through time at the problem.
Thanks a lot for any pointer.
