Adding virtual qualifier to predefined SV Functions
Hi Forum,
In the following code
class root;
 function void abc();
  // Some logic
class ext extends root;
  function void virtual abc();
  // Some logic
A user-defined function in base class could be non-virtual whereas in the extended classes it would be virtual ( and remains virtual even if one were to extend class ext )
However on trying to add virtual keyword to pre_randomize() and post_randomize() I observe a compilation error
As per LRM these functions are not virtual but behave as one due to implicit call before and after randomization()
Does the LRM say they can’t be declared as virtual ?
These methods are automatically declared for every class unless defined otherwise. The prototype specified in the LRM cannot be changed.
Could you please elaborate on the last part
“Unless defined otherwise”
What I meant is that every SystemVerilog class has a built-in pre/post_randomize() method. For a base class, it does nothing. For a derived class, the built-in method callssuper.pre/post_randomize(), continuing up the inheritance chain. When you define pre/post_randomize() in your class, your definition replaces the built-in version for that class.
