Accessing invalid address is not working
Below is small logic for accessing invalid address in case of APB slave verification using systemverilog.
if(enable_wr_invalid_addr_task) begin // accessing invalid address
      apb_transaction trans = new();
      assert(trans.randomize());
      trans.kind = apb_transaction::APB_WRITE;
      trans.addr = `MEM_DEPTH + 4;
       $display("Addr value:0x%h", trans.addr);
      trans.wdata = 8'hDE;
      mbox.put(trans);
while some defines are below which i am using:
`define ADDR_WIDTH 8
`define DATA_WIDTH 8
`define MEM_DEPTH 2**(`ADDR_WIDTH)
some constraints which i am using:
constraint aligned_addr_c { addr[1:0] == 2'b00; }
constraint valid_addr_c { addr inside {[0:`MEM_DEPTH-1]};}
In the above code, trans.addr is not taking the value of `MEM_DEPTH, it is only taking the value of 4. Please guide, i am trying to access the invalid address beyond 0-256 since addr is 8 bit.
You should post a complete example which demonstrates your issue. It’s difficult to determine what is wrong without seeing all variables declared.
You state that you want to access address >256, but address is only 8 bits which allows only 0 -255. What are you trying to accomplish and what isn’t working?
In the apb_generator, i am writing testcases in the task, and enabling them at the top of this file. Now, i am writing testcase to check the invalid address. But the trans.addr in the task is not taking the value which i am assigning in the task. Please guide.
In the above, trans.addr is not taking the value of MEM_DEPTH define, it is only taking value 4 which i am adding to MEM_DEPTH. I am trying to access the invalid address range of 8 bit address. Please guide.
Again, it would be very helpful if you show the complete code you are using, including variable definitions. If trans.addr is only 8 bits wide, then it can only have values 0 to 255. You can’t have any addr value outside of that range.
Hi Cgales,
Please guide, how to write the testcase in systemverilog for writing and reading to invalid address for below memory:
  logic [31:0]mem[256]. // Here we can write 32 bit data to 255 different  locations.
The address bus to your APB slave is 8 bits, which means addresses 0 to 255. Your memory supports 256 addresses, 0 to 255. Your address bus will always contain a valid address.
You have two options:
  1. Make your APB slave address bus bigger than 8 bits.
  2. Make your memory smaller than 256 elements.
