4 process and execution
In reply to Ravi007:
I am presuming that your “process” is a task.
Below is an example. Change the conditions as needed.
module top;
    bit clk, a, b;
    event e1, e2, e3, e4;
        initial forever #10 clk=!clk;
        /* There are 4 processes. Among them in the 1st 3 processes,
        all 3 must get triggered at the same time and run in parallel.
        The 4th process should start after any one process in the 2nd and 3rd gets over
        and the 1st process should also get over.
        When the 4th process starts executing, the pending process
        that did not get over must still continue their execution. Note :
        If the 1st process get over quickly then you must wait for anyone
        process in the 2nd and 3rd process to get over before starting with the 4th process. */
        task automatic c_master();
            bit[1:3] done;
            fork
                c_p(1, done); // process p1
                c_p(2, done); // p2
                c_p(3, done); // p3
            join_none
            wait(done); // any one
            if(done[1]) wait((done[2] || done[3]) );
            else wait((done[2] || done[3]) && done[1]);
            fork
                c_p4(4); // the 4, done is optional
            join_none
        // task automatic c_p(int unit, inout bit[1:3] done); *** BAD ***
        task automatic c_p(int unit, ref bit[1:3] done);
            bit[4:0] delay;
            if (!randomize(delay)) `uvm_error("MYERR", "This is a randomize error")
            repeat(delay+1) @(posedge clk);
            if(unit==1) -> e1; else if(unit==2) -> e2; else if(unit==3) -> e3;
            $display("%t unit= %d", $realtime, unit);
            done[unit]=1'b1;
        task automatic c_p4(int unit);
            repeat(4) @(posedge clk);
            $display("%t c_p4= %d", $realtime, unit);
            -> e4;
        // Start the main task here
            #10 fork c_master(); join_none
            bit va, vb;
            repeat(200) @(posedge clk);
            $finish;
#                  190 unit=           1
#                  230 unit=           3
#                  230 unit=           2
#                  310 c_p4=           4
  1. SVA Alternative for Complex Assertions
    Verification Horizons - March 2018 Issue | Verification Academy
  2. SVA: Package for dynamic and range delays and repeats | Verification Academy
  3. SVA in a UVM Class-based Environment
