I am executing the below code. But getting the error
// Code your design here
class packet;
rand bit [31:0] addr [];
int q[$];
int i;
constraint c1 {addr.size()==32;}
function int prime( addr[i]);
for (int i=0;i<32;i++)
if(addr[i]==1)
return 1;
if(prime(addr[i]))
q.push_back(i);
$display("the value of first 1 is %p", q);
module abc();
packet pkt;
pkt=new();
pkt.randomize();
Error is as below Error-[TCF-CETE] Cannot evaluate the expression
design.sv, 7
“this.i”
Cannot evaluate the expression in single dimension value.
The expression must be compile time constant.
Can anyone pls help me how to proceed
I executed the problem statement as below:
class abc;
rand bit[31:0] data;
task run();
$display("data =%b", data);
for(int i =0; i<32; i++) begin //{
if(data[i] == 1) begin
$display("index =%0d", i);
break;
end //}
endclass: abc
module tb;
abc abc_inst;
abc_inst= new();
abc_inst.randomize();
abc_inst.run();
endmodule: tb
There are few issues in above code:
- You are pushing the array location in the queue and not the position where first 1 occurred. For example, arr[5] = 0000_0000_0000_0000_0000_0000_0000_0100
In this case first 1 lies at position 2, but you are pushing 5 in the queue because you are iterating for 5th array.
I have made few changes and the result is coming as expected. Hope it helps.
class packet;
int q[$];
int y, j;
function int prime(bit[31:0] addr);
for (j=0;j<32;j++)begin
if(addr[j]==1)
break;
return j;
foreach(addr[i])
$display("arr[%0d]=%b", i, addr[i]);
foreach(addr[i]) begin //{
y = prime(addr[i]);
$display("y =%0p", y);
q.push_back(y);
end//}
module abc();
packet pkt;
pkt=new();
pkt.randomize();
