bit clk , a , b , endBranch ;
always #5 clk = !clk ;
sequence branch( a1 , b1 ); // Declared as ' sequence ' to use method ' .ended ' !!
@( posedge clk ) $fell( a1 ) ##[1:5] $rose( b1 ) ;
endsequence
property endCycle ;
@( posedge clk ) branch(a,b).ended |=> $rose( endBranch ) ;
ap_test: assert property( endCycle ) $display("TIME: %2t Assertion PASS " , $time );
else $display("TIME: %2t Assertion FAILS " , $time );
// endBranch Goes True before Sequence branch Completes .
#14 ; a = 1 ; // $fell( a ) is True
#40 ; endBranch = 1 ; // endBranch is True although Sequence ' branch ' hasn't Completed
#2 ; $finish();
Consequent is evaluated only when Antecedent is True i.e sequence ’ branch ’ completes . Hence there is No output ( No Pass / Fail ) for above code
What if I wanted the assertion to check that $rose( endBranch ) isn’t True while sequence ’ branch ’ is still executing .
Eg : For above stimulus I would like assertion to Fail at T:55 since sequence ’ branch ’ isn’t complete .
In reply to Have_A_Doubt:
The ended construct is deprecated. Use the triggered construct
For signal generation, use NBA assignments instead of delays.
Your code had a vacuous property. Most tool have a switch to not display passes (vacuous or nonvacuus).
Test your code in edaplayground
// .ended is deprecated
@( posedge clk ) $rose( a1 ) ##[1:5] $rose( b1 ) ;
endsequence
property endCycle ;
@( posedge clk ) branch(a,b).triggered |=> $rose( endBranch ) ;
$dumpfile("dump.vcd"); $dumpvars;
@( posedge clk ) a <= 1 ; // $fell( a ) is True
repeat(2) @( posedge clk );
endBranch <= 0 ;
b <= 1;
#200; $finish();
In your code the assertion fails as the consequent isn’t True at time:45 units. The Consequent is only evaluated once sequence ’ branch ’ completes .
However the requirement is to also check for $rose( endbranch ) while sequence ’ branch ’ is still executing .
So if $rose( endbranch ) is True while sequence ’ branch ’ is in middle of execution the assertion should ideally fail .
In the topmost stimulus I would like assertion to Fail at T:55 since sequence ’ branch ’ isn’t complete and $rose( endbranch ) is sampled True ( at Time:55 units ) while sequence ’ branch ’ is still executing .
