Hello,
Is it possible to fetch both ISE and Vivado unisim libraries/IPs with usage of [library] section in modelsim.ini? So far got Vivado libraries generated and included, problem arises when I want to add additional precompiled unisim library from ISE (can’t have 2 libraries named the same). Is there a fix for it? I understand that library is a pack of IP’s, so maybe there’s an easy way to put bot ISE and Vivado IPs in one unisim lib?
I apologise if it’s a trivial question, I am not that experienced with modelsim, and did not find answer via google.
Kind regards
In reply to fpga_guy:
This Mentor/Siemens EDA forum is not for tool related issues. Please refer to your tool documentation or contact your vendor support team for additional assistance.
