TLM ports in sequencer and driver
Dear Sir/Madam,
Can I use analysis port/export between sequencer and driver components?
Thanks and Regards,
Sudheer
The uvm_sequencer and uvm_driver already have a port used for passing transactions from the sequencer to the driver called ‘seq_item_export’. You should be using this port for all communications between the driver and sequencer since it is used for arbitration and other sequence control. Is there a reason why this won’t work for you?
In reply to cgales:
Hi Cgales,
Thanks for your response. Actually, seq_item_export is working fine for us. But we just want to know other way of tlm port connectivity.
Sudheer.
In reply to sudheer:
Can you add some additional information about what you are trying to accomplish then and why the seq_item_export doesn’t meet your needs?
