I am developing a new verification environment using OVM and I am curious to know, what people think about “ways to connect components”
There are few ways available
- TLM Fifo
- seq_item_get_ for driver and sequencer
- SV Interface
- home made (uising tasks & functions)
Which was are you using ? Advantages ? Dis-advantages?
All of the first three are used in OVM environments. Interfaces connect the drivers to the DUT. The TLM Fifo is one way to connect two ovm_components. Usually, the components can be connected directly without a Fifo in between. Use a Fifo when connecting two threaded components or two non-threaded components together. The seq_item_prod/cons_if can be thought of as a special purpose TLM interface for connecting drivers to sequencers.
Home made task & function interfaces are not advised. The components aren’t as reusable or flexible.
Thanks…
Can you elaborate more on components can be connected directly ?
IMHO, that is a bad thing since now components needs to know each other and If I were to implement some kind of port between them, rather use TLM fifo.
Please correct and Thanks Again.
The OVM User Guide has a chapter titled “Transaction Level Modeling” that explains it better than I can.
Basically, you have an ovm_component which is a producer of transactions and another component which is a consumer. One or the other is a threaded component. (Usually, a component is threaded because it implements its run() task.) The threaded component is the initiator, it initiates the transaction transfer. The non-threaded component is called the target. Initiators can be producers or consumers, so can targets. There are interface types for all combinations. But an initiator must connect to a target. You only need the FIFO if you’re trying to connect two threaded components (initiators) together or two non-threaded components (targets).
There are more details to concern yourself with, bi-directional interfaces, blocking versus non-blocking calls, and analysis interfaces. The User Guide and Reference documents are the best resources to learn about these things.
Steve
Thanks .
As you suggested, I will refer to the userguide !!
Hi Shail,
Check out the following entry and code samples that I posted not so long ago on my blog…
It shows how you can do connections with or without FIFOs and explains the advantages/disadvantages of each approach. Normally a FIFO should not be used unless you have two independent threads that need to be synchronized.
Back to your original question, each of the first 3 ways you mentioned is used in OVM for a distinct purpose. #1,2 are used for transaction level communication, and #3 is used for signal level communication. #1 is used by monitors to report transactions to analysis elements such as coverage collectors, scoreboards and response sequences. #2 is used by drivers to communicate with sequences.
Avidan Efody
www.specman-verification.com
Thanks Avi.
That makese sense and you are bang on point, about why people tend to use Fifos more.
Apart from difficulty in debug, I would sometime also evaluate performance penalty of using fifo.
-Shailesh
