May I know how I can write another coverpoint that simply sums the other coverpoints instead of crossing them?
Thank you.
In example below, I just need to know celln_o has toggled 0 to 16, celln_u has toggled 0 to 16, tmonin_o has toggled 0 to 4 and tmonin_u has toggled 0 to 4.
class n_class;
rand n_struct n_randc;
constraint c {
n_randc.celln_o < 17;
n_randc.celln_u < 17;
n_randc.tmonin_o < 5;
n_randc.tmonin_u < 5;
n_randc.celln_o != n_randc.celln_u ;
n_randc.tmonin_o != n_randc.tmonin_u ;
covergroup cg;
celln_o : coverpoint n_randc.celln_o { bins b1[] = {[0:16]}; }
celln_u : coverpoint n_randc.celln_u { bins b1[] = {[0:16]}; }
tmonin_o : coverpoint n_randc.tmonin_o { bins b1[] = {[0:4]}; }
tmonin_u : coverpoint n_randc.tmonin_u { bins b1[] = {[0:4]}; }
chgdis : coverpoint n_randc.chgdis ;
endgroup
function new();
cg = new();
endfunction // new
Could you elaborate more on what you mean by “sums the other coverpoints”?
You also mentioned that you want to know that celln_o has toggled 0 to 16, Do you mean toggle (transition) coverage of 0 to 16 or state coverage of all values of 0 to 16?
I will try my best to explain another way.
If I were to cross celln_o, celln_u, tmonin_o and tmonin_u, then the total combination would be 17x17x5x5=7225 combinations
But I only require 17+17+5+5=44 combinations.
How would one write a coverpoint for 17+17+5+5 ?
Honestly, it’s still unclear to me, but I can sense from your answer that you already have what you want covered in the coverpoints celln_o, celln_u, tmonin_o and tmonin_u.
But if you are interested in covering only some specific combinations of the values of celln_o, celln_u, tmonin_o and tmonin_u, you can create a cross and specify those combinations by ignoring any combination that doesn’t meet your requirement. Here is a simple example that you might look at
module m;
logic [3:0] a, b;
covergroup cg;
// Cover values 0 to 7 of a
cp_a : coverpoint a { bins val[] = {[0:7]};}
// Cover values 0 to 14 of b
cp_b : coverpoint b { bins val[] = {[0:14]};}
aXb : cross cp_a, cp_b {
// By default cross all values of 0 to 7 of a with 0 to 14 of b.
// If you want to exclude some combinations
ignore_bins ignore = binsof(cp_a) intersect {5};
// If you want to define illegal combinations
illegal_bins illegal = binsof(cp_b) intersect {15};
endgroup
cg cg_inst = new();
Actually, I would like to use get_coverage() to check if it hits 100% for the 44 combinations.
Currently, I have I coded this way:
for (int i=0;
n_inst.cg.celln_o.get_coverage() < 100.00 ||
n_inst.cg.celln_u.get_coverage() < 100.00 ||
n_inst.cg.tmonin_o.get_coverage() < 100.00 ||
n_inst.cg.tmonin_u.get_coverage() < 100.00;
i++) begin
assert(n_inst.randomize());
So is there a better way I could write a coverpoint so that I can use get_coverage() on that and simplify the above for loop condition.
If that had been mentioned earlier, it would have been much more helpful :)
I would assume you also would like to get 100% on chgdis if that’s the case then why not calling get_coverage on the covergroup level i.e. n_inst.cg.get_coverage() < 100.0 ?
otherwise, one suggestion is splitting cg into 2 covergroups.
Oh I didn’t know we could do that!
Thank you for your help.
Apologies for the unclear posts :)
