module top;
class A;
int array[] = {1,2,3,4,5,6,2,4,5,7}; // Here 3 numbers are repeated (2,4,5)
rand int arr1[], arr2[];
constraint c {
arr1.size() == array.size/2;
arr2.size() == array.size/2;
foreach(array[i])
if (array.sum() with (int'(item == array[i])) == 2 ) {
// element is repeated must be in both arr1 and arr2
array[i] inside {arr1} && array[i] inside {arr2};
} else {
// element is not repeated must be in arr1 exclusive arr2
(array[i] inside {arr1}) != (array[i] inside {arr2});
A h = new;
initial repeat(2) begin
assert(h.randomize());
$display("arr1: %p arr2: %p",h.arr1, h.arr2);
