I have downloaded the Register Example (SPI Block Level Register Testbench) and ran the testcases. The default test case(spi_reg_test) is failing due to register mismatches.
I am getting following mismatches:
Virtual sequence get_full_name = t_seq
UVM_ERROR …/sequences/spi_bus_sequence_lib_pkg.sv(444) @ 889000: uvm_test_top.m_env.m_apb_agent.m_sequencer@@reg_seq [REG_TEST_SEQ:] poke/peek: Read error for rxtx2: Expected: 96caab59 Actual: 8ee02fc
UVM_ERROR …/sequences/spi_bus_sequence_lib_pkg.sv(444) @ 895000: uvm_test_top.m_env.m_apb_agent.m_sequencer@@reg_seq [REG_TEST_SEQ:] poke/peek: Read error for rxtx1: Expected: dbddcf1d Actual: 810ceb04
UVM_ERROR …/sequences/spi_bus_sequence_lib_pkg.sv(444) @ 907000: uvm_test_top.m_env.m_apb_agent.m_sequencer@@reg_seq [REG_TEST_SEQ:] poke/peek: Read error for rxtx0: Expected: 1bce4f76 Actual: 377e8a22
UVM_ERROR …/sequences/spi_bus_sequence_lib_pkg.sv(444) @ 919000: uvm_test_top.m_env.m_apb_agent.m_sequencer@@reg_seq [REG_TEST_SEQ:] poke/peek: Read error for rxtx3: Expected: 880afa80 Actual: 6acd6b40
UVM_ERROR …/sequences/spi_bus_sequence_lib_pkg.sv(444) @ 931000: uvm_test_top.m_env.m_apb_agent.m_sequencer@@reg_seq [REG_TEST_SEQ:] poke/peek: Read error for rxtx2: Expected: 4bdbd084 Actual: 8ee02fc
Do you have a fix for this?
