Sequence layering/nesting and generating ethernet data packets
Hi all, I have a question regarding sequence layering.
If I want to generate Ethernet packets: preamble-sfd-dest.addr-source.addr-…
Is sequence layering the best way to do it?
I looked at the example in ovm cookbook’s codes, that example illustrated how to layer multiple words into a burst. But in the Ethernet case, the length of preamble, sfd and etc are different, so I must creat individual sequence classes for them right? Is the inter-layer translator a MUST in this case?
Another thought is using nesting sequences, in the packet sequence body():
task body()
//generate preamble sequence;
// then generate sfd sequence;
But I don’t quite understand how to implement the driver to handle such sequence, since the sequence is longer than one clock cycle, so I guess @(posedge clk) would’t work?
Any thoughts?
