Question about 'seed' and randomization
helle everyone:
i have a question about seed and randomization. i know that different seeds will generate different random sequence, but how does the seed affect the results of the randomization??
for example: there is a 8-bit variable: rand op in class a, i can chose different seeds such as 1, 2, …, i will repeat 200 times, how can i know the difference of randomization result when i chose different seeds? thank you !!
I am not exactly sure what you are trying to do. Can you please elaborate what are you trying to achieve?
You mean to say that you want to see how many random values of your random variable has hit? If that is the case, go for coverage.
Or else, explain in more detail. :)
Ashish
Choosing a different seed does not guarantee a different random result. It increases the probability of a different result. It also changes the distribution of results when you ask for sequences of random results.
Take a 2-bit variable as an extreme example. You have only four possible random results - 0, 1, 2, and 3. If you run with 4 seeds, you many not get all possible values, such as producing just 1 and 2. But if your test ask for a series of random values, each seed may produce a sequence of values. For example,
Seed 1 → 1,2,0,1
Seed 2 → 1,3,1,0
Seed 3 → 2,1,0,3
Seed 4 → 1,3,1,0
Note that each seed does produce a unique sequence of 4 numbers. You might have to run longer simulations to see differences in the sequence of results.
Dave
Ashish
thank you , my intention is just like dave said !!
Seed 1 → 1,2,0,1
Seed 2 → 1,3,1,0
Seed 3 → 2,1,0,3
Seed 4 → 1,3,1,0
Dave
thansk, as you said, do you mean that we still can not estimate the distribution of values in the sequence before we try many times simulation? is there any arithmetic for the randomization ?
You can not estimate exactly the sequence beforehand unless you get hold of the randomization engine’s algorithm. But keeping all other factors unchanged, you can be sure that a seed will give the same result everytime it is used. Randomization is deterministic.
As the fundamental philosophy behind “random testing” is “random”, there is NO arithmetic, though there certainly is a logic/algorithm behind the scene. Let me turn the table and ask: what exactly are you looking for and why? Are you trying to “optimize” your runs to get a faster coverage closure? Are you trying create complicated, but unique tests? If it is first, I recommend you look at ACC (Automatic Coverage Closure: http://sv-verif.blogspot.com/2009/02/automatic-coverage-closure-my.html). Remember that ACC is a “necessary” but not sufficient goal for tapeout and heavily depends on your coverage model completeness.
If it is the “smart tests” or higher level tests, you may want to look at ITG - read: http://sv-verif.blogspot.com/2009/03/itg-c2d-acc-emerging-verification.html
Also a recent post from user of Trek is at: http://www.verificationguild.com/modules.php?name=Forums&file=viewtopic&p=15324#15324
HTH
Srini
www.cvcblr.com
HTH
Srini
www.cvcblr.com
i am sorry , i can not open the link: http://sv-verif.blogspot.com/2009/02/automatic-coverage-closure-my.html
Strange, perhaps your firewall settings? Or an interim outage? I just now checked and am able to see it. I am posting a copy here, but then there are 4 replies including those from Director of nuSym offering more useful insights. So do visit that link when it works for you.
Wednesday, February 18, 2009
Automatic Coverage Closure – my perspective
Recently EDA tools are emerging in the area of “Automatic Coverage Closure” that promise a new level of automation in CDV/MDV/any_other_Buzz_word_Driven_Verification process. A significant name in this arena is nuSym, a relatively new EDA player. There have been few good reviews about them @ Deepchip.com.
http://deepchip.com/items/0479-05.html
http://deepchip.com/items/0473-06.html
http://deepchip.com/items/dvcon07-06.html
And another one @ SiliconIndia:
http://www.siliconindia.com/magazine/articledesc.php?articleid=DPEW289996212
And very recently on VerifGuild:
http://www.verificationguild.com/modules.php?name=Forums&file=viewtopic&t=3102
I like Gopi’s post/comment b’cos I have the same opinion about CRV (Constraint Random Verification) – it catches scenarios/bugs that you didn’t envision – either via constraints or coverage (or otherwise). Now if we fool ourself by going behind “only the existing/identified coverage holes” we fall into a trap. This is inline/insync with what Sundaresan Kumbakonam of BRCM ( need his profile? See: http://vlsi-india.org/vsi/activities/dvw05_blr/index.html) shared with me once:
Quoting Sundaresan:
I don’t believe much in the idea of “writing functional coverage model” and then tweaking a constraint here-or-there, or writing a “directed test” for it to fill the hole.
Coming back to my view, I believe some redundancy via randomness/CRV is actually good. In my past verification cycles I have seen design errors due to “repeated patterns” – no big deal, is it?
So where exactly do these ACC tools fit?
Referring back to:
whether these tools are only used to reach last few % of coverage goal which is hard to reach ?
I would differ here, they shall be very useful somewhere during the middle phase – neither too early, nor too late. Too early – perhaps we don’t have full RTL and/or functional cov model. Too late – perhaps our focus should be more into “checking” than only coverage (As Nagesh pointed out in VerifGuild). I would like to add that during those last minutes, the coverage shall be taken for “granted” – meaning it is a must and not a nice to have thing and the focus shall be to look for any failures.
To me a reasonable flow with these ACC tools would be:
Run with CRV, measure code coverage. Add checkers
Add functional coverage, use CRV again to hit them using the coverage points as “potential trouble spots” than “actual scenarios” themselves. In few cases where in the scenario description is easy to capture using Functional coverage syntax, this is great. IMHO the existing coverage syntax is little too verbose and unusable to a large extent for solid, easy-to-use coverage specification. Specifically the SV syntax overhead of coverage is just too much for me. IEEE 1647 “e” fairs slightly better but that’s a different story altogether. I’m still on the lookout for a higher level coverage specification language… (matter for another blog post anyway).
Once the RTL and the coverage model is reasonably stable, use ACC regularly as a “sanity” test on every interim RTL release. I believe ACC has a HUGE potential here – if we can optimize the tests needed to release interim RTL versions, we are saving quality time and enabling faster turn around.
Towards the end, enable “plain CRV” (without the ACC bias) and look for “trouble free regression for XX days”.
And while speaking to a friend of mine here a while back, he is damn against the idea of using these ACC tools for merely stimulus. He likes the idea of ACC if it can be used to:
Fill functional cov holes
Code coverage holes
Assertion cov misses/holes
A tough ask, but looks like nuSym can handle that – atleast based on the early reviews so far. Also reading their whitepaper on “intelligent verification”, they do a path tracing that enables them to systematically target code coverage without getting into Formal world – cool idea indeed! Kudos to nuSym folks (some of them my ex-colleagues BTW).
And on the application of these ACC tools to the poor, non-CRV/CDV folks – there is light at the end of the tunnel, if you read nuSym’s paper. We at CVC also have ideas on how to use this for a highly configurable IP verification with plain vanilla verilog/task based TBs. We need to prototype it before we can discuss it in detail though.
Anyway, good topic for otherwise a downturn mood.
More to follow.
Srini
P.S. Sorry for the “random” rambling, after all we are talking of “random verification” :-)
