Python-based OVM Register code generator using Excel-generated XML File
Contributor: Shashi Bhutada
Date: January 20, 2009
Description:
This is a simple implementation of generating OVM register code using an Excel-generated XML file which is written in particular format (Read the README file in the package for the exact format).
This is work in progress. The generated code should be a good starting point for someone to reuse the code for their usage.
The python parsing can be used as an example for XML parsing of IPXACT format file or any other Excel format that users might have.
BETA2: Corrected the "ss:" error. Please send email to shashi_bhutada@mentor.com for any errors you see or any suggestions you have for enhancing this.
Download: ovmRegGen.BETA2_0.zip
