| Contributor: | Ning Guo |
| Date: | June 24, 2009 | |
| Description: | PW OVM SCOREBOARD RELEASE 1_4This is the fourth release of the PW SVF Scoreboard Component. This release and future updates are also available at https://sourceforge.net/projects/pwsvf/files/Scoreboard/pw_svf_scoreboard-1_4_0.tar.gz/download This release has the following enhancements: Added configuration fields to scoreboard class to allow turning on/off data display from testbench or tests ------------------------------------------------------------ Release 1_3 Enhancements: - Supporting all three major vendors: VCS/ MTI/ CDN ------------------------------------------------------------ Release 1_1 Enhancements: - Changed scoreboard method post_sb_data from function to task to allow timeout handling in scoreboard extensions. - Post and Check counts now tracked and reported per stream. - New counts added to track transactions that timed out and droppable transactions dropped.Also tracked and reported per stream. - Droppable transactions now removed from scoreboard prior to End of Test check for outstanding transactions remaining. - More tests are added to the example ------------------------------------------ PW OVM Scoreboard Features include: - Supports scoreboarding through TLM interfaces - Supports scoreboarding through procedural interfaces - Supports both in-order and out-of-order checking - Supports creation of complex DUT-specific transfer functions - Timeout checking - Has hooks for error handling - Is extendable |
| Download: | pw_svf_scoreboard-1_4_0.tar_0.gz |
