| Contributor: | Jim McGrath | |
| Date: | December 9, 2008 | |
| Description: | Perl based OVM template generator for OVM 2.0The attached perl script will generate ovm templates similar to ivb. It uses a simple template file to provide the base name, variables and interface ports.
The template files should be self-explanatory. The only deficiency is in the generation of the field macros in the sequence item class. jivb.pl currently only supports "ovm_field_int" and "ovm_field_int_array" types automatically. The user can insert other variables types with the "ovm_var" keyword, but will have to edit and fix the sequence_item field macros manually. jivb is intended for users without access to the more fully featured ivb template genarator. |
| Download: | jivb.tar_2.gz |
