| Contributor: | David Larson | |
| Date: | July 12, 2011 | |
| Description: | OVM Harness - How to reuse interface connectionsThis whitepaper shows how to hierarchically reuse interface connections from the block to chip level. |
| Download: | ovm_harness_whitepaper-synapse.pdf |
How you are defining your interface so that you can both monitor and drive the ports?
Are you using modports and clocking blocks?
