i have a problem ,when i use ovm_do to randomize my sequence_item, i also want some property like content[$] to be set equal to constant value , so i use mid_do function to set req.content[0]==* … but it turns out to be wrong , i am confused … help me ~~
It’s hard to tell what it wrong with the limited information that you posted.
I would recommend that you don’t use ovm_do macro or mid_do.
Instead, use the function API directly. It makes debugging problems a lot easier.
In your body…
$cast(txn_handle, create_item(transaction_classname::type_id::get(), m_sequencer, “name”));
start_item(txn_handle);
// Do what you need to do to set transaction fields, randomize, etc. here
finish_item(txn_handle);
See the OVM reference for more information on create_item, start_item, and finish_item.
-Kurt
thanks kurts, i think i may not clearly describe my problem.
for example
class my_trans extends ovm_transaction
rand bit a;
rand bit [7:0] payload[$];
the class have two property ,and i can add constraint in sequence to send my_trans with a=1,
class my_seq_1 extends ovm_sequence #( my_trans)
task body;
`ovm_do_with(req,{req.a==1})
but how can i constraint payload to a constant array ? if in some sequence i need payload[0]=h30,payload[1]=h40,…
Here are two ways you could do this:
call rand_mode(0) on your transaction field before randomizing (e.g. txn.payload.rand_mode(0)) and then assign directly to the payload array.
In your constraint, use the foreach construct:
{ foreach ( payload[i] ) payload[i] == other_constant_array[i]; }
There is probably another, easier way, but these two ways are what I can think of off the top of my head.
-Kurt
