OVM COMMAND LINE ACCESS
Contributor: John Rose
Date: November 3, 2009
Description:
The OVM comand line access package provides access to all command line arguments used in a simulation. Unlike $value$plusargs and $test$plusargs, the command line access package gives a list of matching arguments so that it is possible to use an argument more than once on the command line. The package also provides arguments for accessing the configuration mechanism (+ovm_set_config_int=<value>, +ovm_set_config_string=<value>) and for accessing the factory (+ovm_set_inst_override=<value>, +ovm_set_type_override=<value>).
Download: ovm_command_line_0.tgz
