function new (string str=“pmc_svt_i2c_system_configuration”);
super.new(str);
num_slaves = 128; // 128 new slaves
int i;
/** Create port configurations */
create_sub_cfgs(num_masters, num_slaves);
for(i=32'h20 ; i < 32'h60 ; i ++) begin
slave_cfg[i].is_active = 0;
slave_cfg[i].slave_address = i[9:0]; // `SVT_I2C_SLAVE0_ADDRESS;
slave_cfg[i].bus_speed = HIGHSPEED_MODE;
slave_cfg[i].enable_10bit_addr = 0;
On compiling the above code, the following error is thrown.
Error-[SE] Syntax error
“/nfs/fm/disks/001/config.sv”,
22: token is ‘int’
int i;
System verilog keyword ‘int’ is not expected to be used in this context.
Why can’t we use the variable int or bit in the function new?
You can, but SystemVerilog requires all variable declarations precede all procedural code. The statement ‘num_slaves = 128;’ is procedural, so declaring ‘int i’ can not come after it. Move the declaration of ‘i’ to the top of the function.
Since SystemVerilog allows user to declare variables within begin … end block
the variable i could be also defined as following right ? ::
function new (string str="pmc_svt_i2c_system_configuration");
super.new(str);
begin // Added to declare variable(s)
int i;
// Remaining code here
