in the code:
ifdef INCA include “ovm.svh”
else include “ovm_macros.svh”
import ovm_pkg::*;
`endif
which part of code is in Questa?
if INCA is defined, the codes are used in Questa or not?
in the code:
ifdef INCAinclude “ovm.svh”
elseinclude “ovm_macros.svh”
import ovm_pkg::*;
`endif
INCA, SVPP macros are automatically defined when you use Incisive tool. So “`else” part is meant for Questa.
If you manually define INCA while using Questa, it will be treated as normal macro:)
Saurabh Sharma
Thank you very much for your reply.
However, there is another question here. Look at the codes in ovm_pair.svh, from line 93 to line 106.
[I]virtual function string convert2string;*
string s;
ifndef INCA* *$sformat( s , "built-in pair : %p , %p" ,* *first ,* *second );* *else
$sformat( s , "built-in pair : " ,
first , " , ",
second );
`endif
return s;
[/I]
I think the else part is for Incisive tool, because I find the corresponding part in AVM3 update3(in file avm_pair.svh, from line 94 to line 102):
string s;
$sformat( s , “built-in pair : %p , %p” ,
first ,
second );
return s;
[/I]
Do you think it is perhaps omitted while converting AVM to OVM?
Thank you very much again.
Yes, You are correct here “`else” part is for Incisive tool. This function will return the same string, INCA macro is used here just to show that OVM comes from 2 different but close friends:D
BR,
Saurabh
No, the functions do not return the same string. %p is for pretty printing, which is a new feature in the 1800-2008 LRM. It descends through the class object and prints the values of all the class properties. Without %p and when firstand secondare class handles, that has always been illegal without a format specifier.
Dave
Thank you for your reply, but I am a little confused. Do you mean it is illegal in the else part?
Thank you very much!
Thanks I learnt something new.
but
[HTML]Do you mean it is illegal in the else part?[/HTML]
BR,
Saurabh
OK, illegalmay be too strong a word; undefined, definitely. Handles, which include classe, object variables, events, virtual interfaces, and chandles have no user-visible defined values. The $display family of system tasks say that unformatted arguments be displayed by default as a decimal number, and that any other aggregate typed argument be formatted. There is no explicit cast of a handle to an integral value defined, so I believe any implicit cast of a handle is illegal.
Dave
Thank you for your reply. I wish a new version of OVM can come out soon with all the little problems fixed.
`ifndef INCA
means for Questa
