I have a legacy task in a module, which I want to be made available to a class.
The easiest way is to:
create a task in a virtual interface.
call the legacy task from this task using hardcoded paths.
access this virtual interface’s task from a class.
The problem with the above approach is (2) hardcoding of paths.
Now I see the SV manual says that if you define a task as extern in an interface, you can import or export it via modports to other classes/modules. That way you won’t have to hardcode paths.
But the problem is extern isnt supported by questa 6.3d.
Do you guys have any ideas how to avoid hardcoding of paths?
I have worked with several customers who have faced with the same issue. While creating reusable class-based uVCs with customers, I have used following technique that does not use extern functions. Being said that extern tasks/functions are supported in Incisive since then.
* The goal of this example is to demonstrate how to reuse tasks/
* functions of a legacy VIP (module based TB) in a class based
* TB. As you might have thought, the ugly way of doing this is
* to used OOMR in the CB-TB but then the CB-TB become
* non-reusable.
* The main care about while doing this is not to use OOMR and
* have clean interface between CB-TB and MB-TB. OOMR are not
* acceptable because
* (a) It breaks the reuse and scalability
* (b) if you have multiple instance of CB-TB and MB-TB then you
* have to keep modifying interface definitions with new OOMRs
* and some form of case statement to ID various instances.
* The cleaner way of doing this to create a wrapper BFM module that
* contains an "interface" and legacy BFM. The interface will define
* tasks/functions that will call tasks/functions from legacy BFM.
module legacy_bfm;
task automatic foo(input int x, output int y);
y = x+1;
$display("Lagecy BFM: got x=%0d, returning y=%0d", x, y);
endtask // automatic
interface mb_driver_if;
task foo_if(input int x, output int y);
bfm.foo(x, y);
endinterface
module driver_wrapper;
legacy_bfm bfm();
mb_driver_if ifc();
module tb_top;
class cb_driver;
virtual interface mb_driver_if vif;
function void set_vi(virtual interface mb_driver_if I);
vif = I;
endfunction // void
task run();
int y;
vif.foo_if(53, y);
endtask // run
endclass // cb_driver
driver_wrapper driver_wrapper_i();
cb_driver cb = new;
cb.set_vi(driver_wrapper_i.ifc);
cb.run();
endmodule // tb_top
Can u please send me some example code for following steps.
I am ok with using hardcoded paths.
Regards,
Payal
Hello,
Is there something in OVM which might help?
thanks,
Srishan.
