Hello,
I would like to know if it is possible in the factory to use set_type_override on a parametrized extended class (to override both class and parameter types). I currently use OVM libraries.
In my example below the goal is to keep driver_generic generic so I don’t want it to be dependent of a specific transaction.
My example compile but I have this FATAL message at run time :
OVM_FATAL @ 0: reporter [FCTTYP] Factory did not return a component of type ‘driver_generic’. A component of type ‘ab_cd_driver’ was returned instead. Name=drv Parent=agent_generic contxt=ovm_test_top.env_h.ab_cd_agent_h
Thank you for your explanations.
class inputnop_tran extends ovm_sequence_item;
class driver_generic #(type P = ovm_sequence_item) extends ovm_driver #(P);
class ab_cd_driver #(type P = inputnop_tran) extends driver_generic #(P);
class agent_generic extends ovm_agent;
driver_generic drv;
function void build;
super.build();
drv = driver_generic#()::type_id::create("drv", this);
endfunction : build
endclass : agent_generic
class environment extends ovm_env;
agent_generic ab_cd_agent_h;
super.build();
ab_cd_agent_h = agent_generic::type_id::create("ab_cd_agent_h", this);
// Type override
driver_generic#(ovm_sequence_item)::type_id::set_type_override(ab_cd_driver#(inputnop_tran)::get_type());
endfunction : build
endclass : environment
