I am pretty much confused or dont have an idea on how to connect the OVM test bench to the “SystemC” golden reference model.
I would like to connect a TLM fifo sending the transaction from the sequencer to the “systemC” golden reference model, which in turn the output from the reference model is used for comparing the results.
Can any one post a simple example just explaining the steps connecting the TLM fifo from the sequencer to the systemC reference model and the same in the OVM environment!!
At the moment, there is no standard interface between SC and SV. Some vendors have provided prototype implementations.
If you are using Questa, there is a very small example in the installation directory <…>/examples/systemc/systemc_dpi. You can contact us directly for a complete example using OVM/TLM.
If you are using Incisive there are mixed language capabilities available in Incisive for doing this. There is an example that is very close to what you
are describing posted here:
@Dave: Whome I should contact for the complete example, and can you post some contact info plz sir,
@Stuart: Thank you for the same, but if you have more or less an example with the OVM env, interconnected with SystemC reference model that would be very helpful…
Dave Rich
Whome should we contact to get a complete example using OVM/TLM, can you kindly guide me to get the same, which would be very useful for my project works!!
Thanks in Adv,
Desperado: —> Trying hard to learn this above concept :mad:
Hello All,
Thanks for your replies, its giving an overview but not clear!!
Hello Experts,
Can any one kindly please atleast post an overlay or just the hint of code to connect an systemC ref model with an OVM architecture, I am dead stuck in middle of my project, Kindly help me out!!!
Hello Dave,
Had mailed up all the details as u mentioned, but havent got any reply yet back, kindly plz do the needful help on the same… wish u look into this !!
