Is it possible to change the severity of a debug message dynamically in the run phase i.e.
based up on the value of a signal, I want to change the severity of a block OVM_ERROR messages to OVM_INFO and then back to OVM_ERROR?
In reply to SKUPPAM:
You can’t change the severity of messages in OVM (you can using UVM).
You can suppress the message through either its verbosity, or by the action associated with a message.
In UVM this is easy - there is a set_report_severtiy API. I did a quick look in OVM, I don’t find it (I don’t use OVM that much nowadays, so maybe I am missing). However you can change the action via the below API:
function void set_report_severity_id_action_hier( ovm_severity severity,
string id,
ovm_action action )
HTH
Srini
www.verifworks.com
Thanks for the quick response. is there a way with some OVM hack code to achieve the same UVM feature?
You can extend ovm_report_server class and then ovverride the process_report virtual function.
Here’s how I done it.
class my_report_server extends ovm_report_server;
virtual function void process_report( ovm_severity severity,
string name,
string id,
string message,
ovm_action action,
OVM_FILE file,
string filename,
int line,
string composed_message,
int verbosity_level,
ovm_report_object client
//compare id or message for which you want to change severity
if(id == "your_id")
severity = OVM_INFO;
super.process_report(severity,name,id,message,action,file,filename,line,composed_message,verbosity_level,client);
endfunction: process_report
endclass: my_report_server
//Then you have to set your class as default report server in your testcase
function void start_of_simulation();
ovm_report_handler report_handler = get_report_handler();
my_report_server my_server = new();
report_handler.m_glob.set_server(my_server);
Hope this works for you
In reply to M_Dave:
Thanks Dave. Looks it is working.
