How do I show SV preprocessor output?
I’ve run into some compilation errors in my testbench. OVM uses a lot of preprocessing-macros (`define), so I’m having a hard-time tracking down the offending statements.
Is there a way to tell irun (6.20s004) to dump the SVPP’s output? I tried
irun -log_svpp mylogfile.txt -svpp
, but mylogfile.txt only displays a summary of the files-compiled (not the raw preprocessor output, which is what I need.)
The svpp output is written to the INCA_libs/irun.lnx86.06.20.nc/svpplib directory - you may have seen error messages related to the files here that svpp generates. These are the “raw” SystemVerilog files that I think you are wanting to see?
Regards,
Dave
I checked that inca*/svpplib directory, but the svpp_mod.map is almost empty. It shows the header (“Original File” … “Modified File”), but no actual entries follow.
Sorry, I wasn’t being clear. By “raw” files, I’m referring to the (text ASCII) output of the preprocessor, after all macro-substitutions have been made. I wanted to inspect these files, so I could see the “postprocessed” Systemverilog files, just before the compiler starts crunching them.
Let me see if this example helps:
macro1.sv (original, starting source-file)
`define **SILLY_EXAMPLE( first, second )** first``second
module macro1();
integer x =1;
integer y = 2;
integer xy = 0;
initial begin : main
  **`SILLY_EXAMPLE(x, y)** = x + y;
  $display( "x + y = %d", **`SILLY_EXAMPLE( x, y )** );
end : main
endmodule : macro1
After Systemverilog-preprocesser:
module macro1(); // **<-- this is the file I want to see!**
integer x =1;
integer y = 2;
integer xy = 0;
  ***xy*** = x + y;
  $display( "x + y = %d", ***xy*** );
end : main
endmodule : macro1
The svpp preprocessor is used to translate code that contains parameterized classes to a specialized class for each parameter used. It does not touch macros - these are passed to the compiler (which knows how to process them).
I don’t know if there is a way to get irun to show you the code after macros have been expanded. That is something you will have to ask your Cadence rep.
Regards,
Dave
It seems I was looking in the wrong direction, thanks for the clarification!
You can use -E outputfile on the vlog command line with Questa.
Dave
To revisit this issue …
Starting in Verdi 2008.01, the source-code browser has the option to do inline-expansion of Verilog/Systemverilog define macros. (Before, you had to move the mouse over the macro, and Verdi would popup the substitution-test.)
This feature is accessed by launching verdi with the command-line variable verdi -macrodebug (and setenv EXPAND_MACRO_DEBUG 1)
Does Simvision have a similar feature? Sometimes I want to see the inline-expansion of `ovm_* macros, because it’s more convenient then keeping multiple editor-windows open.
