Hierarchical reference in package
Hi All ,
I’m getting this error , During elaboration time ,
Error :
Remove hierarchical reference from the package
    I'm having the normal function that is presents in the TB,
I want to call the function from OVM package. Whether its applicable or not , because i’m seeing in some sites & SV PDF .
"Items within packages cannot have hierarchical references ".
Below are the code for Function call in package:
         sample_tb.display_function (a,b,c);
Karthik G
In reply to Karg188:
The content of a package does not have any position in the topology of a testbench. For this reason it is not legal to use hierarchical paths in a package. This is not a limitation. You have to import the package content in the component you want to use a member of a package. Then it is available in this place.
