I have one simple example which uses TLM get_port and get_export/get_import and it gives some error while running in Questa 6.6 version.
Please go through the example code and point out the problem.
module tlm_lab;
import ovm_pkg::*;
`include “ovm_macros.svh”
class pkt;
rand bit[31:0] addr;
rand bit[7:0] data;
class generator extends ovm_component;
pkt p;
ovm_blocking_get_imp #(pkt,generator) gen_tlm;
//ovm_blocking_get_export #(pkt) gen_tlm;
// Constructor - Required syntax
function new(string name, ovm_component parent);
super.new(name, parent);
gen_tlm = new (“gen_tlm”,this);
$write( " generator new called ");
endfunction : new
virtual task get(output pkt pp);
p = new();
assert(p.randomize);
$display(“%p”,pp);
pp = p;
endclassclass driver extends ovm_component;
pkt dp;
ovm_blocking_get_port #(pkt) drv_tlm ;
drv_tlm = new (“drv_tlm”,this);
$display( "drive new called ");
endfunction : new
task run();
repeat (10)
dp = new;
drv_tlm.get(dp);
$display(“%p”,dp);
#10;
pkt dp;
endfunction : new
task run();
repeat (10)
dp = new;
drv_tlm.get(dp);
$display(“%p”,dp);
#10;
generator gen = new("gen",null);
driver drv = new("drv",null);
initial
drv.drv_tlm.connect(gen.gen_tlm);
$display( " CONNECT is called here ");
// connect tlm
drv.run();
$finish;
ERROR msg from Questa 6.6
generator new called drive new called
** Fatal: (SIGSEGV) Bad handle or reference.
Time: 0 ns Iteration: 0 Process: /tlm_lab/#INITIAL#64 File: /tools6/Questa6.6/questasim/linux/…/verilog_src/ovm-2.1/src/tlm/ovm_ports.svh
Fatal error in file /tools6/Questa6.6/questasim/linux/…/verilog_src/ovm-2.1/src/ovm_pkg.sv
HDL call sequence:
Stopped at /tools6/Questa6.6/questasim/linux/…/verilog_src/ovm-2.1/src/tlm/ovm_ports.svh 96
called from tlm_lab.sv 52
called from tlm_lab.sv 71
Thanks in Advance.
