Error-[ICTTFC] Incompatible complex type usage
I am setting the config object in the build phase of base test and getting it inside the sequence using m_sequencer handle.
Code Below,
Base Test:
de_slave_config=i3c_slave_config::type_id::create(“de_slave_config”);
set_config_object(“*”,“i3c_slave_config”,slave_config,0);
Sequence:
m_sequencer.get_config_object(“i3c_slave_config”,slave_config,0);
Suppose If I use the same handle which I used in the base test in the (ovm_object value → de_slave_config ,m_sequencer.get_config_object(“i3c_slave_config”,de_slave_config,0);) field , I am not seeing this error.
Slave_config is a just a handle to collect the object address.
Why I am seeing this error if I use different name in ovm_object value field.
Error Msg:
Incompatible complex type usage in task or function call.
The following expression is incompatible with the formal parameter of the
function. The type of the actual is ‘class
LPIO_SB_I3C_MS_ENV_LIB.lpio_pkg::i3c_slave_config’, while the type of the
formal is ‘class OVM_VAL_LIB.ovm_pkg::ovm_object’. Expression: slave_config
Source info: this.m_sequencer.get_config_object(“i3c_slave_config”,
slave_config, 0)
Venkatesh
In reply to muthuven:
The error message tells you that you are trying to downcast the handle without using $cast.
See Why downcasting is not allowed in SystemVerilog? | Verification Academy
Thanks Dave for the reply.
Resolved it now.
