I am facing an issue with passing a dynamic array with
`ovm_do_with
and
ovm_do_on_with.
The following is the snippet of the code.
Can anyone please help me on this ?
class my_trans extends ovm_sequence_item;
rand bit [127:0] data [];
//---> Configuration
`ovm_object_utils_begin(my_trans)
`ovm_field_array_int ( data, OVM_ALL_ON)
`ovm_object_utils_end
function new (string name = "my_trans", ovm_sequencer_base sequencer = null, ovm_sequence parent_seq = null);
super.new(name, sequencer, parent_seq);
endfunction : new
endclass : my_trans
And in the sequence now i am passing dynamic array like this
class my_seq extends ovm_sequence #(my_trans);
rand bit [W_DATA-1:0] data_local ;
// OVM automation macros for sequences
`ovm_sequence_utils(my_seq, my_sequencer)
// Constructor
function new (string name = “my_seq”);
super.new(name);
virtual task body();
data_local=new[2];
data_local[0] = 128’hDBE7DBE7DBE7DBE77EBD7EBD7EBD7EBD;
data_local[1] = 128’hE7DBE7DBE7DBE7DBBD7EBD7EBD7EBD7E;
`ovm_do_with(req,{req.data == data_local;})
endclass: my_seq
<span style="font-family:'Courier New'">
<font size=2><span style="font-family:'Arial'">
<font color=Blue>But above passing mechanism is NOT working.
<font color=black>
Regards,
Santosh</font>
</font></span> </font></span>
I think that doing direct assignment of the data fields as Dave shows above is often not a good idea. The reason is that it circumvents the constraint solver (ie the constraint solver has no knowledge or control over the values that are assigned). If there are other constraints in the system that rely on these fields then illegal stimulus may be generated.
Even if this problem does not arise in this specific testbench, it may arise when the components are reused later.
A better approach is to use the foreach construct with the equality constraint. Another approach is to use set_mode() to turn off randomization for those fields and then assign them. The advantage of this approach over Dave’s suggestion is that the constraint solver can still properly evaluate other constraints that may apply to these fields.
I tend to agree with you if the fields being manually assigned are usually randomized, but not in the case where the fields will alwaysbe explicitly assigned, or alwaysa derivative of other random values. I don’t know what the original poster’s intent was, and having a field declared with or without therand modifier will show the user’s intent.
Also note that in SystemVerilog, a call to req.randomize(null) will check the validity of the constraints with the current state of all fields without randomizing.
However there is a discrepancy w.r.t. to Dave’s solution. The " ’ " construct i.e.
dynamic_array = '{'hEAB7EAB7}; will not work in IUS but works in Questasim.
As a result, to have uniformity across tools, its advisable to use foreach construct within the constraint.
As per suggestions, I tried with “foreach” constraint but the dynamic array DIDNOT get the values what I specified through data_local and req.data value is zero. Did I miss something ?
Oh, we all missed the fact that if you are using constraints, you also need a constraint on the size of the dynamic array to allocate two elements.
Also, with regard to the “'”; that is now optional in this case. The “'” in front of {}'s mean follow the rules for assignment patterns, without it, follow the rules for unpacked array concatenation - to align with C/c++. For single dimensional unpacked arrays of integral values, there’s no difference between the two forms when specifying a list of integral values. Differences start showing up when you have multiple dimensions of dynamically sized arrays.
