I am a newbie for OVM. I read that get() call is equivalent to calling get_next_item, followed immediately by item_done.
So my question if get() does the function which get_next_item() and item_done() together do, then why there is a need for two different functions ?
Sorry, after reading the article, I can understand the two use models and how they work. However, it is still not clear where it is possible to insert the delays?
With get(), the function item_done() is immediately called after the get_next_item() task, so if you want to have a delay between get_next_item() call and item_done() call, then in that case you should separately call get_next_item() and item_done().
