Creating Specific coverpoint bins based on another fields - Functional Coverage
In reply to santosh_kumar_vangala:
You can do something like the following to create bins for values inside the valid_dest_addr
     bins addrs_bins[] = des_addr with (item inside {valid_dest_addr} );
However the glitch here is that the Covergroup has to be constructed (via new()) after the valid_dest_addr array is populated, otherwise it will be meaningless.
