When I tried to run the xbus_integration examples using demo.sh. But I am getting following errors.
file: …/…/sv/ovm_rgm_pkg.sv
if($cast(r, this) && (r.get_register_kind()==RGM_SHARED || r.get_register_kind==RGM_INDIRECT )&& name==“”)
ncvlog: *E,FUNOTR (…/…/sv/ovm_rgm_base.sv,551|83): A function (not called) is not a legal rvalue [10.3(IEEE)].
if(regs[i].get_full_name_list(s, this) != ADDR_ERR) begin
ncvlog: *E,TYCMPAT (…/…/sv/ovm_rgm_container.sv,1079|38): formal and actual do not have assignment compatible data types (expecting datatype compatible with ‘queue of string’ but found ‘dynamic array of string’ instead).
bytes=b;
ncvlog: *E,TYCMPAT (…/…/sv/ovm_rgm_reg_op.sv,173|10): assignment operator type check failed (expecting datatype compatible with ‘dynamic array of byte’ but found ‘queue of byte’ instead).
if(tmp_reg.get_register_kind==RGM_INDIRECT)
ncvlog: *E,FUNOTR (…/…/sv/ovm_rgm_sequencer.sv,175|37): A function (not called) is not a legal rvalue [10.3(IEEE)].
package worklib.ovm_rgm_pkg:sv
errors: 4, warnings: 0
