Hi Team,
I would like to validate my RTL based on the C-Reference Model. Can someone provide an complete working example showing how the C function Outpts are used to compare with RTL output in scoreboard.
Thank You in Advance,
Surya
Hi Team,
Surya
Hi Surya,
thanks for your question. You mention C-Based Stimulus - for a description and example see the CBasedStimulus cookbook page.
However I think what you are really asking for is not stimulus but rather a golden reference model, written in C and instantiated using SV DPI alongside an SV/UVM Scoreboard.
While this is a fairly standard technique and is described well in the SV documentation, regrettably we don’t have a full example of that here in the UVM Cookbook. You can find several useful DPI papers on the internet or perhaps someone can recommend a favorite one here.
In reply to gordon:
hi gordon,
the example you mentioned in CBasedStimulus cookbook page could not be opened because of unexpected broken. could you please upload a new one or could you email me a copy? Thanks very much.
In reply to dylan:
Hi Dylan,
You can use “gzip -d filename.tgz” to decompress tgz file to .tar file.
Then you can use “tar -zxf filename.tar”.
Regards,
DungA
Hi, I think I’m facing the same question with you. I want to bring in the golden C model in and compare the output from golden model and hardware.
Did u find some examples or valuable files? Can u share it to me ?
In reply to leapoo:
Hi Leapoo,
Use DPI function calls (export’s & import’s)to achieve this.
To know how to do this refer to
uvm_cookbook_recipe_of_the_month_cbased_stimulus_for_uvm_tfitzpatrick.pdf
Also, Please try to get something out of the example provided by the Gordon.
Regards,
Surya
