Hello All,
How do we return an queue or dynamic array from a function? I’ve tried and getting compilation error.
Is it possible?
ovmboy
Hello All,
Is it possible?
ovmboy
Yes you can, but you must use a typedef to define the return type. That is because the BNF does not allow you to put an array range to the right of a function name.
typedef bit bitstream_t[$];
function bitstream_t my_funct(input bitstream_t arg);
Dave Rich
I did this but an error says “inappropriate use of bit select” pointing to chk_data_error[i].
This is my code:
typedef bit data_error[];
virtual protected function data_error chk_data_error (int unsigned bc, bit [8:0] data_bit_err[]);
this.chk_data_error = new[bc];
for(int i=0; i<bc; i++) begin
this.chk_data_error[i] = |data_bit_err[i];
endfunction : chk_data_error
In reply to Reuben:
Don’t put
this. in front of the function when using it as a return value.
virtual function data_error chk_data_error (bit [8:0] data_bit_err[]);
chk_data_error = new[data_bit_err.size];
foreach(data_bit_err[i])
Ok thanks! It’s working! =)
