Assertion error
Hello
I have an OVM enviorment with one interface. Interface contains few assertions. The problem is, when I add the assertions to the wave window it is not taking. It gives an error like
(vish-4014) No objects found matching ‘/g_tb_top/g_if/a1/*’.
Same kind of error I’m getting when I run xbus example too. I’m not getting what kind of an error is this. Similar kind of assertions are working fine with pure SV enviorment.
Below I give the asserion what I’m using
property Pr_1;
@(posedge sig_tx_clk)
$rose(tx_en) |-> (tx_data==8’hb);
a1: assert property(Pr_1);
I appreciate your valuable suggestions.
Thanks & Regards
Leeja Mathew
This is the process to be followed when u want to debug the assertions in Questasim.
Here are the steps to view the assertions in Questasim in xbus example provided in OVM World.
U can debug the Assertions using ATV (Assertions Thread view) in Questasim.
Add timescale in xbus_tb_top.sv file as follows
`timescale 1ns/1ns
  1. Compile the file with +acc option
    vlog +acc -f compile_questa_sv.f
  2. Simulate xbus_tb_top with -assertdebug option
    vsim -assertdebug +OVM_TESTNAME=test_read_modify_write -suppress 3829 xbus_tb_top
  3. Add the signals log
    add log -r sim:/xbus_tb_top/*
  4. Add the require assertions to the Assertion Thread viewer (ATV).
    atv log -enable /xbus_tb_top/xi0/*
  5. Run the simulation
    run -all
  6. Now from Top menu open the assertion window as follows.
    view → coverage → assertions.
  7. At the end of window select any concurrent assertion(example: assertAddrUnknown) and right click and select view ATV.
    or
    Add the required assertion using following command.
    add atv /xbus_tb_top/xi0/assertAddrUnknown 135ns
Now u can see the Assertion thread and allows easy debug.
If u find any doubt go to the Questasim help and search for ATV
